Page 2 of 3
Re: SAV Swiss Style LED Taillights
Posted: Tue Apr 01, 2014 11:42 am
by berger
Haf-e wrote:I had installed new all-red LED truck combo tail / brake lights units into the original Pinzgauer housing - it worked well but the view of them off angle was limited. Looked more like the originals.
You don't need to change the flasher if you are only upgrading the rear lights - they front filament bulbs provide the load on the original non-electronic type flasher.
Awesome! Thanks for that tip!
Posted: Thu Apr 03, 2014 4:20 pm
by 66north
LED lamp very similar to original Pinz lamps available in UK. My company has an account with this company so I'm happy to source them if anyone interested.
http://www.dun-bri.com/vehicle_lamps/re ... /30758965/
Posted: Thu Apr 03, 2014 5:21 pm
by GenevaPinz
Nice design. 122mm diameter is indeed the same as the original tail lights.
Posted: Sat Apr 19, 2014 1:00 pm
Before installing these tail lamps be sure the turn signal switch is
CLEAN, FREE FROM OIL AND DRY OR THEY WILL NOT WORK!
Spent a couple hours tracing down circuit bleed due to dirty oily t sig switch
Had to replace the switch for them to work.
I personally do not like LED tail lamps because when they go do bad you have to replace the whole assembly
Posted: Wed Jun 11, 2014 5:13 pm
by berger
Bought a set... I will do an install when I get them.
Posted: Wed Jun 11, 2014 6:00 pm
- CIMG3318.JPG (115.55 KiB) Viewed 9769 times
Kept the original and added LED from Grote. Very bright and take the place of the reflector.
Posted: Sun Jun 15, 2014 2:30 pm
by berger
For you guys that installed these LED taillights, could someone explain why the connection at the break reservoir is removed and capped, and the brake wire that was on the brake reservoir extended and reconnected to the headlight terminal?
I am not replacing the flasher as the headlights are still bulbs.
Posted: Sun Jun 15, 2014 2:57 pm
My guess is: "Just cuz". I'd ask Willy. In many respects, LED bulbs do not provide the same load characteristics as filament bulbs. Here's a link to some info:
http://www.superbrightleds.com/carbulb_notes.php
Obviously, these bulbs have some non-stock characteristics, as evidenced by the need to run the SAV blinker relay. Speaking of which...
Looks to me as if you will
have to install one of those relays, based on the notice in the instructions. I don't think it's an option. Perfect time to call Willy, order the flasher, and inquire about the brake switch wire.
Posted: Sun Jun 15, 2014 4:32 pm
by David Dunn
From that short statement, it's to separate the turn/brake lamps
Posted: Sun Jun 15, 2014 5:08 pm
by David Dunn
I miss part of what Berger wrote. You disconnect the pink wire from the switch and is extended and connected to the brake master cylinder switch. At the back of the vehicle, the pink wire is connected to the stop lamps...
The wire is not reconnected to the light switch
Posted: Sun Jun 15, 2014 9:23 pm
by berger
Thx David.
I cannot get this. The wiring is done exactly like the instructions.....other than the new flasher unit, which guys stated here wasn't needed. Perhaps I should have ordered that unit regardless.
I had a mix of functionality, but now that the pink wire, or what looks closest to pink, from the right side of the light switch lever, is connected to the plug behind the master cylinder using a spade connector. The only lights I get now are the hazards, and then only the passenger side. Nothing else works.
Colours do not come through well...
LHS
RHS
I don't have the patience for this.
Posted: Sun Jun 15, 2014 10:21 pm
by David Dunn
It's been 12 + years since I changed my lights on my 710, and then 712, and between senility and oldtimers
, what I remember was the change is straight forward , just swap the 3 wires and add the pink for the stop lamps. This is for the Swiss Pinzes. Austrian Pinzes already have separate turn/stop.
Be sure you didn't reverse the black and brown. Brown is the ground, unlike what people on this side of the pond are use to.
Posted: Mon Jun 16, 2014 1:36 am
I will add to my earlier comments so you understand , Normally the brake and turn share a bulb (yellow brake and turn) these new lamps use a separated signal(amber turn/red stop) that is why you bypass the brake switch output to the pink wire . If you have circuit bleed try blowing out the t sig switch with compressed air, NO OIL
If you suspect a bad flasher go to the auto parts store and buy a 12v EL13 flasher(around $12) and install it , it will work.
X=green, P=blue, L=yellow/black
Posted: Mon Jun 16, 2014 11:20 am
by berger
Thanks guys. Even though the cables are slightly faded, the brown is definitely on the negative. Am I correct in connecting the two black wires, on the LHS, together on the one spade terminal?
I am going to get the new flasher, thanks Jim, and try that.
Posted: Mon Jun 16, 2014 11:38 am
berger wrote:Am I correct in connecting the two black wires, on the LHS, together on the one spade terminal?
Yes you are correct. One black wire is suppling the power to the tail light and the other continues it on to the license plate lamps.
