Page 2 of 5
Re: Big smoke, big oil mess, big problem! Advice/confirmati
Posted: Fri Aug 08, 2014 9:49 am
by stiffler4444
on another side note, I ordered the civilian ignition kit from Scott yesterday...figured it was time......
Had the Pertronix installed when I bought it, but nothing else. This should smooth things out once it's running good again.
Posted: Fri Aug 08, 2014 12:33 pm
by berger
stiffler4444 wrote:on another side note, I ordered the civilian ignition kit from Scott yesterday...figured it was time......
I am interested to see if your Petronix is installed "the wrong way," like mine was. No real issue when installing the civi kit though.
Posted: Fri Aug 08, 2014 12:52 pm
by stiffler4444
I am interested to see if your Petronix is installed "the wrong way," like mine was. No real issue when installing the civi kit though.[/quote]
How did you realize it was wrong? I'm curious, might wanna check mine....
tx Dave
Posted: Fri Aug 08, 2014 7:09 pm
by berger
stiffler4444 wrote:I am interested to see if your Petronix is installed "the wrong way," like mine was. No real issue when installing the civi kit though.
tx Dave
Something to do with the red wire. Scott advised me. Not ideal, but functions fine. PC new what THEY were doing I guess....
Posted: Fri Aug 08, 2014 10:26 pm
by stiffler4444
Good to know. Thanks Berger.
Posted: Thu Aug 14, 2014 9:44 am
by stiffler4444
Got my new air filter today from Trupart.com. Fram CA 3105, will throw that in tonight ahead of tearing into the spark plugs and whatnot this weekend. Terrible time of year to be down.....
Posted: Fri Aug 15, 2014 2:36 pm
by pinzton
[Moved the previous post here - as per suggestion to it's own 'new' thread: Big white smoke , all RPMs.... Advice? ]
I might be in a similar situation; all advice appreciated. Context:
- I bought a 712m after it's engine was rebuilt 3 years ago; it had perhaps 500 miles since then
- Drove it 20 miles, then HUGE white smoke coming out of exhaust at all RPMs
- Oil level was SUPER low; I refilled it. It keeps it since then (but not driving much except for trial if it's still blowing white)
To check what's going on, this is what I did...
....continues in thread: ]Big white smoke , all RPMs.... Advice?
Posted: Fri Aug 15, 2014 8:57 pm
When oil is sucked up into the intake, it reaches the rear carb first, so I suspect that's what's happening and why you see it in the 3&4 cyl's only - it hasn't reached the front carb yet. I suspect that if you remove the airbox, it will have oil in it.
The truck can inhale and burn a lot of oil rapidly, if the intake is blocked or restricted.
Posted: Tue Aug 19, 2014 6:45 pm
by pinzton
Thanks Undysworld, I'll check the air intakes - and will update my findings here
Posted: Tue Aug 19, 2014 10:54 pm
by berger
pinzton wrote:Thanks Undysworld, I'll check the air intakes - and will update my findings here
Perhaps a new thread to update? Kinda a highjack when someone posts about an issue they are having and another, perhaps similar or different issue, interrupts the OP and muddies the water. Just saying .
Posted: Wed Aug 20, 2014 12:39 pm
by GRCameron
Perhaps this could be tried as a diagnostic...
Remove the ventilation hose (p/n 900.0916/07). and cap the inlet nipple to the air intake where the hose was. Leave the hose fitting on the oil fill pipe open or route it away from the engine through a long hose. This ventilates the crankcase to atmosphere and precludes any oil making it into the engine through the carbs. Run it for awhile and see if the white smoke clouds go away. A few hours of crankcase emissions making it to the atmosphere will not cause major trauma to the environment.
(My '06 Dodge Cummins has a factory road draft tube...)
Posted: Wed Aug 20, 2014 1:33 pm
by stiffler4444
GRCameron wrote:Perhaps this could be tried as a diagnostic...
Interesting....... :idea:
Posted: Wed Aug 20, 2014 4:37 pm
by pinzton
berger wrote:pinzton wrote:Thanks Undysworld, I'll check the air intakes - and will update my findings here
Ok, will do
(note: I'm new to the forum, so happy for all posting advice. I posted here, because I thought it's a similar issue and the previous post can profit from the answers as well)
Posted: Wed Aug 20, 2014 6:40 pm
Check 3 things in this order, (1) with air box off carbs, look down rear carb throats wile running, if it drips, the the float valve is not seating. Excess fuel washes out the rings. next steps require tear down, (2) check for out of round cylinder, cylinder scored, fractured piston, rings not seating. (3) very bad valve guides
stock ring gap is .5mm-1mm
Posted: Thu Aug 21, 2014 7:26 am
by stiffler4444
Jim LaGuardia wrote:Check 3 things in this order, (1) with air box off carbs, look down rear carb throats wile running, if it drips, the the float valve is not seating. Excess fuel washes out the rings. next steps require tear down, (2) check for out of round cylinder, cylinder scored, fractured piston, rings not seating. (3) very bad valve guides
Thanks Jim. Hope to remove the air box and get into it Friday after work.
