Page 3 of 5
Re: Big smoke, big oil mess, big problem! Advice/confirmati
Posted: Fri Aug 22, 2014 4:29 pm
by stiffler4444
Ok didn't have much time this aft but got the air box off and.......ya full of oil.
Posted: Sat Aug 30, 2014 10:06 am
by stiffler4444
OK, so the source of oil is the dipstick tube. She's flowing out the top pretty good. Does that indicator point to anything in particular?
Posted: Sat Aug 30, 2014 10:25 am
Stekay wrote:I'd start at the beginning. Compression or preferably a leak down test. Check condition of the plugs as you pull them. A hard run at high RPM could've hurt a piston or rings, or burned a valve. Wishing for the best that it's a clogged breather or something simple.
As Stekay said a compression test or preferably a leak down test. This may help what is causing the excessive crankcase pressure you seem to be experiencing and hopefully rule out Jim's suspicion of washed out cylinders.
Have you pulled and examined the spark plugs yet?
Posted: Sat Aug 30, 2014 11:12 am
by stiffler4444
Definite problem with one of the cylinders. Oily and showing signs of backfiring damage
Posted: Sat Aug 30, 2014 11:31 am
by stiffler4444
Ya compression test is next. One plug is a real mess.
Posted: Tue Sep 09, 2014 6:16 am
by stiffler4444
Just picked up a compression tester kit, will be working on it this week or weekend. I pulled all of the plugs (had to buy a generic 13/16 lawn mower tool to get them all out). 2nd cylinder is the only one producing an oil soaked and damaged spark plug. The rest look good and uniform.
I will check out the compression numbers on all cylinders and post up results.
tx Dave
Posted: Thu Apr 02, 2015 9:32 am
by stiffler4444
Ok, she slept for the winter, but is slated for compression testing this weekend, Saturday I figure. Wish me luck..... :roll:
Posted: Wed May 20, 2015 11:36 am
by stiffler4444
Ok, so compression test done, #1 - 135, #2 - 0, #3- 125, #4 - 135.
So #2 has a serious problem! Anyway, going to get some compressed air in there and see where the leak is from (under the guidance of my mechanic brother in law, of course).
Parts order from EI coming by the end of next week I'm sure!
tx Dave
Posted: Mon Jun 08, 2015 6:23 am
by stiffler4444
ok, so as previously mentioned, the second cylinder from the front was 0 on the compression test. We put some compressed air in there and had a lot of bypass coming out the oil filler tube and nowhere else. Pulled the head and cylinder and voila! A nicely F'd piston.
So, when replacing the piston and cylinder (I know I can hone the cylinder, but for arguments sake, lets say I'm replacing both), does it matter if I use a 92MM, 92.5mm or 93mm, as long as the piston and cylinder match? Do I need to match them to the remaining 3?
tx Dave
Posted: Mon Jun 08, 2015 6:26 am
by stiffler4444
Here are the pics of the culprit
Re: Big smoke, big oil mess, big problem! NEW pics and ques
Posted: Mon Jun 08, 2015 6:28 am
by stiffler4444
Also, I'm guessing that I need to buy a tool to remove the piston, is there are common variant?
Posted: Mon Jun 08, 2015 11:55 am
by pinzinator
I wonder what would cause a failure like that? Did a part of the piston break off and hammer the cylinder?
You should go with the same size piston and cylinder as stock to keep the engine in balance. The piston/rings and rod assemblies should all weigh the same, so if you go with 92.5 or 93 mm pistons you could have vibration problems or bearing failure eventually.
Posted: Mon Jun 08, 2015 12:58 pm
by stiffler4444
Thanks, yes, I've established that I need 92mm and have ordered that. As for cause, still trying to figure that one out. looks like the piece of the piston did detonate, not sure the cause. Valves are all good, so heat is likely not the issue. Oil is fresh and in good supply. :?: :?: :?:
Posted: Mon Jun 08, 2015 1:22 pm
No special tools to remove the piston. Just remove the retainer and slide the pin out, you will have to remove the #1 piston to remove the bad #2 piston. If the pin is stuck, use a nut and long bolt through the pin and pull it out.
Posted: Mon Jun 08, 2015 1:26 pm
by stiffler4444
Jim LaGuardia wrote:No special tools to remove the piston. Just remove the retainer and slide the pin out, you will have to remove the #1 piston to remove the bad #2 piston. If the pin is stuck, use a nut and long bolt through the pin and pull it out.
Thanks Jim, I was wondering if I had to remove any other pistons. A great help as always!
