Heater
Heater
Well... just went you thought you had seen it all... I found this GREAT way to install a heater in a Pinz :mrgreen:
Ok, so perhaps not the best way but it is an interesting concept - plywood backboard is not the nicest thing to look at/through but the heater uses propane and is a catalytic heater.
Not sure how well the radiant heat would work with its placement but interesting.
Perhaps in the summer a hole could be cut in the plywood and a window A/C unit could be installed :)
Pinz Heater Mod.jpg (134.5 KiB) Viewed 5162 times
Re: Heater
burned coats and scarves!
Is there tip over protection? Does it trigger while driving and shut off?
oilcan
Re: Heater
Post by oilcan »
maybe put in a fire pit in the bed? :D
Brickren
Re: Heater
Post by Brickren »
Just like a Volkswagen. Right side gets 2nd degree burns while left side gets frostbite. only with this, its ears instead of feet.
1975 710M
2000 Ural Tourist
Re: Heater
Painting the plywood to match the vehicle color would at least it improve the aesthetics.
NEWFISHER
Re: Heater
Post by NEWFISHER »
You could also grill cheese sammys reaching over with your left hand whilst keeping the shifter hand on task.
Re: Heater
This is weird. There is an ad for a 712 on Ebay right now, with this exact catalytic heater shown. 10th photo shown. Says it's in Michigan ???
http://www.ebay.com/itm/Pinzgauer-1982- ... 2002110578
Same vehicle???
Re: Heater
Yeah - that is where I got the picture from
When I 1st saw it I thought it was a plug in electric heater :)
Re: Heater
I think perhaps we thought it was your heater solution.
But in all honesty, looking back on things you have accomplished, it did seem a bit primitive for you and really not up to your standard. Apologies if I seemed to be confused at the beginning of the postings.
Re: Heater
krick3tt wrote:I think perhaps we thought it was your heater solution.
Ah - well the way I said it in my 1st post I could see how that would come across
I was just being sarcastic
