Bore Pitch Question
bikmakr
Bore Pitch Question
Post by bikmakr »
I can't find it anywhere. Does anyone know the distance between cylinders (pitch)in mm?
Re: Bore Pitch Question
Boy that's a tough one. If you have your crankshaft out you could measure it there.
Sees like you could measure the on center distance between the exhaust bolts for each set of cylinders and then average the three values to get a pretty good approximate value.
Any issue with this idea?
bikmakr
Post by bikmakr »
Turns out to be 132mm
