Bore Pitch Question
Posted: Mon Jan 11, 2016 3:32 pm
by bikmakr
I can't find it anywhere. Does anyone know the distance between cylinders (pitch)in mm?
Re: Bore Pitch Question
Posted: Mon Jan 11, 2016 9:50 pm
by rmel
Boy that's a tough one. If you have your crankshaft out you could measure it there.
Posted: Tue Jan 12, 2016 12:10 am
by Haf-e
Sees like you could measure the on center distance between the exhaust bolts for each set of cylinders and then average the three values to get a pretty good approximate value.
Any issue with this idea?
Posted: Tue Jan 19, 2016 4:57 pm
by bikmakr
Turns out to be 132mm
