2.7 factory engine
gunipinzmutt
Italy
2.7 factory engine
Post by gunipinzmutt »
Is there any possibility to know, from outside, if an engine has 2.7 litre displacement?
A 712k in military tropical version should carry such engine?
An engraved sign "TL" close to engine number has any meaning in this matter? What does it mean?
Thanks for your help.
Pinz: 710 m, 710 ms, 710 k, 712 m fla, 712 k, 716 m, 718 m san, 716 k, 718 rehinbraun
Haflinger: 700, 703
G: 250, 270, 400, 350
Unimog 406
M825, M151 A2, M416
Fiat Panda 141A 4x4
Fresia F18
Re: 2.7 factory engine
The only Factory built 2.7L engines I am aware of were in a couple of race trucks.
waterdog
Paraguay
Post by waterdog »
Image Mine came with this stamp on it....
1985 710MS
1985 712MK
That is not a factory marking.
Your mod is aftermarket work.
gunipinzmutt
Italy
this is my engine, could it be 2.7L?
2015-06-13 15.41.02.jpg (1.18 MiB) Viewed 7319 times
Haflinger: 700, 703
Unimog 406
M825, M151 A2, M416
Fiat Panda 141A 4x4
Fresia F18
CentAr712
Post by CentAr712 »
For some reason I was thinking that they actually built some of the later ambulance trucks with a 2.7 stock from the factory, but that it was low numbers because it was so near the end of the gassers production. I'm probably wrong, but for some reason I'm thinking this.
Chris.
https://www.supanik.com/pinz
ako
Post by ako »
CentAr712 wrote:For some reason I was thinking that they actually built some of the later ambulance trucks with a 2.7 stock from the factory, but that it was low numbers because it was so near the end of the gassers production. I'm probably wrong, but for some reason I'm thinking this.
I read this somewhere as well.
My friend's workshop truck that was '85 was not a 2.7L though.
