Driver side head light does not work on high beam
ziegler
Post by ziegler »
Just put on the 7" LED head lights I scored on ebay and everything was fine until a couple days ago. Now the high beams don't work on the drivers side. Any info on how I can trouble shoot this is appreciated. Thanks Zig
Re: Driver side head light does not work on high beam
The left high beam is circuit breaker #5. That's the first thing I would check and if not that then remove the headlight and check with your multimeter that all wiring is as it should be.
Good luck!
ziegler wrote:scored on ebay
This may be the issue
Not sure what you got but sometimes ebay is just full of junk
Hopefully not in your case and just a loose wire!
