Hello to all.
It seems like an eternity since I last posted here. I have been away from Volvos for over six years but now find myself back in the saddle again. My brother recently moved his 1975 AluZn TGB11 up from Texas. It has been sitting idle for the eight years and is now being brought back to life.
I cannot find the parts cross-reference list that was so useful years ago. Having Tatanka now in the picture certainly makes C-series ownership far more friendly. I am pressed for time a bit and need to access front brake shoes and wheel cylinders ASAP. I know the these parts match up with Land Rover Series 2a LWB trucks but was wondering if anyone still had the exact LR part numbers tucked away somewhere.
Take care.
Jim Molloy
Waldersee Farm
Sheridan, Oregon
Volvo C-series/Land Rover brake parts cross-over numbers
Jim Molloy
Re: Volvo C-series/Land Rover brake parts cross-over numbers
This page?
http://www.angelfire.com/extreme3/sgrig ... aneous.htm
In order to keep a copy in this forum, here's the cross-references parts.
Code: Select all
Part Name Part Manufacturer Part Number Other Vehicles used in Original/ Replace/ Improve/ Accessory Comments Cost (Country)
Air Filter Volvo 681609
Air Filter Beck/Arnley 042-1355 Replace VERIFIED (USA) / Advance Auto Parts
Air Filter NAPA FIL2170 Replace Gold quality (VERIFIED) $8.50 (US)/NAPA
Air Filter NAPA SFI 22170 Replace Silver quality VERIFIED $5.49 (US) / NAPA
Axle Boot Volvo 1563012 Original Group E-Mail from Brian Steen
Brake reservoir cap Volvo 1272107 (product # 236298-001) Replace
Oil Filter Fram PH7328 Volvo 164 Replace VERIFIED $4.18 (US)
Oil Filter Pennzoil PZ104 Replace Not Verified Yet $3.59 (US)
Oil Filter Purolator L14670 Volvo 164 Replace VERIFIED $2.88 (US)
Oil Filter Purolator PL14670 Volvo 164 Replace VERIFIED $5.88 (US)
Oil Filter K&N HP1009 Replace Gold Quality (Not Verified) $9.98 (US)
Oil Filter Advance Auto Parts AA16 Replace Not Verified Yet $2.48 (US)
Oil Filter Beck Arnley 0418145 Replace Not Verified Yet $10.99 (US)
Oil Filter Mann W917
Spark Plug Wire Set Autolite 86100 Replace VERIFIED (Attaches to screw-on cap\, not screw threads) $21.99 (US)
Spark Plug Wire Set Xact 6050 Replace Not Verified Yet $15.99 (US)
Spark Plug Wire Set Beck Arnley 1752336 Replace Not Verified Yet $15.99 (US)
Spark Plug Wire Set Bosch 09021 Replace Not Verified Yet $18.99 (US)
Spark Plug Wire Set Standard 9638 Replace Not Verified Yet $22.99 (US)
Spark Plug Wire Set Mileage Plus MP W2610 Replace Not Verified yet $14.99 (US) / NAPA
Spark Plug Wire Set NAPA (Belden) BEL700165 Replace Not Verified Yet $19.99 (US)
Sparkplug A/C R43F3 Replace Not Verified Yet
Sparkplug Bosch W6BC Original
Sparkplug Bosch 4232 Replace Not Verified Yet
Sparkplug NGK 4085 Replace Not Verified Yet
Sparkplug Autolite 275 Replace VERIFIED (0.028 Gap)
Sparkplug Champion 929 Replace Not Verified Yet
Distributor Cap Bosch 1 235 522 053 1973/1974 Capri 2600 / 2800 Original
Distributor Cap Mileage Plus Electrical EP406SB Replace VERIFIED $5.99 (US) / NAPA
Distributor Cap Beck/Arnley 1742741 Replace Not Verified Yet $13.49 (US)
Distributor Cap GP Sorenson 225015 Replace Distributor #0 237 300 001 VERIFIED $12.29 (US) / Advance Auto Parts
Distributor Cap Bosch 03008 Replace Not Verified Yet $16.99 (US)
Distributor Cap Niehoff FF60H Replace Not Verified Yet $7.49 (US)
Distributor Cap Echlin EP406 Possibly Porsche 911 Turbo
Distributor Rotor GP Sorensen 235113 Replace VERIFIED $8.69 (US) / Advance Auto Parts
Distributor Rotor AC Delco F403 Replace Not Verified Yet $5.49 (US)
Distributor Rotor Bosch 04017 Replace Not Verified Yet
Distributor Rotor Bosch 1 234 332 173 Original VERIFIED $13.69 (US) / NAPA
Distributor Rotor Echlin ECH EP407 Replace VERIFIED $6.49 (US) / NAPA
Distributor Condenser Bosch 1 237 330 273 Replace Not Verified Yet
Distributor Rotor Beck/Arnley 173-7527 Replace VERIFIED $7.99(USA) / Advance Auto Parts
Points Bosch 1 237 013 078 Original Not Verified Yet
Distributor Bosch 0 231-303-058 original
Fuel Filter (Rear) Fram G2 Replace VERIFIED - out of fuel tank $2.50(US) / Wal-Mart
Lower radiator hose NAPA NBH 8207 REPLACE 2 pieces are needed Verified $13.69 (us)"
Vacuum lines for lockers Gates NBH H-190 REPLACE Verified$3.09 / 6ft (us)"
Thermostat NAPA THM 238 Volvo 164 Replace Needs a gasket (THM 1070)Verified $6.99 (us)"
Thermostat gasket n/a THM 1070 Volvo 164 Replace Verified $1.09 (us)
Relay 24v N. O. Hella 003510141 replace It will replace Bosch relay 24v N.O. $32.00 us"
Relay 24v N. C. Hella H41388501 replace It will replace Bosch relay 24v N.C. $32.00 us"
Fuel filter/ pressure regulator Filter King 99901.419 Replace From Pierce Manifolds 408-842-6667 or 800-874-3728 $ 60.00 US
Front brake flex line Precise Lines 571.106 #106 Volvo 1800/122 Improve stainless steel IPD p/n PL 671799
Fan V belt NAPA XL25-7350 Replace 25/64 x 35-5/8 9.5/10mm x 905mm "NAPA"
Fan V belt Volvo 930282 IMP 7179 Original 9.5mm x 888L
Brake shoes-front Land Rover RTC 3424 LR series II 109 SW w/ 2.6L petrol 1971 replace
Brake shoes-rear Land Rover STC 2797 LR Series II 109 SW w/ 2.6L petrol 1971 replace
Wheel cylinder-right rear Land Rover 243296 LR Series II 109 SW w/ 2.6L Petrol 1971 replace
Wheel cylinder-left rear Land Rover 243297 LR Series II 109 SW w/ 2.6L petrol 1971 replace
Door handle Volvo 64321 IMP Original
Dashboard warning lamp Sylvania 3797 osram 13913 Philips 13913 model is replaced by 3797 Osram (at www.topbulb.com) $1.50 (US)
Wheel cylinder front left Girling (Lucas\, Lockheed) 600200 Land Rover Series 109 LWB 6 cylinders Replace Verified $140 CND per pair
Wheel Cylinder front right Girling (Lucas\, Lockheed) 600201 Land Rover Series 109 LWB 6 cylinders Replace Verified $140 CND per pair
Radiator cap Volvo 461646 B18/B20 1967-73 original
Clutch casing drain plug Watts/Anderson-Barrows Metal Corporation A-710/PB109 Replace 1/8 NPT plug-square head brass replaces original steel plug) $0.92 Lowe's Home improvement
Valve Cover Gasket Felpro VS26067 Volvo 164 Replace VERIFIED $12.49 (US)
Valve Cover Gasket Beck Arnley 0360750 Volvo 164 Replace Not Verified Yet $9.59 (US)
Upper Radiator Hose Volvo 644132 Original
Windshield Wipers Blades Trico 18-1 n/a Replace VERIFIED- VinceAtReal4x4s
To add one little note to that, those Rovers are often referred to as the "NAS" 109's (North American Spec)
That 6cyl was a gutless old thing, in case anyone was wondering.
It's the "glow in the dark" engine (exhaust manifold), especially if ignition timing is not perfect.
