John Deere, HMMV or Land Rover Hitch Receiver options
boeing7873
Argentina
Post by boeing7873 »
Anyone tried this receiver straight into the 4 bolt pindle pattern without removing the cone?
Any thoughts?
https://www.kfiproducts.com/john-deere- ... eiver.html
or
https://www.palletforks.com/john-deere- ... 2-6x4.html
JC
Jerome
CRJ Driver
Garrycol
Re: John Deere Hitch Receiver
Post by Garrycol »
Being for a John Deere - do they have the right load capacity?
1973 Haflinger AP700
1977 Landrover FC 101
2007 Range Rover Sport TDV6
1957 Landrover 88"
boeing7873
Argentina
True, did not find any specs on load testing, but with a little common sense, I would have no problem in using it for a light trailer... not your Airstream!
Here is another option... My interest is not removing the tailcone, but only the pindle.
http://www.coolcruisers.com/hirefj.html
Jerome
CRJ Driver
There's this unit from SAV as well http://www.pinzgauer.com/showdetails.ph ... no=SAV5520
IMHO a more basic mounting. I believe someone on the Forum came up with this design years ago and a few people
out there have been replicating it. I have one but have had no need to use it as of yet but it's handy to have.
boeing7873
Argentina
Yes, and I wonder why it is $129 at SAV.
EI has the same unit for $99!
https://expedition-imports.com/PNZRCVR
Jerome
CRJ Driver
A $30 dollar Olive Drab paint job maybe :shock:
The hitch receiver EI was selling (in the link) is the one I was making since 2001. Another "infamous" Pinz dealer attempted to sell them to SAV as his own design... which didn't go so well and SAV made some mods to the design (and not for the better imo) and has been selling it ever since. Up through 2011 I had made over 350 receivers and I know of at least 2 other people that are selling copies of it.
As for the John Deere hitch, there are 2 different tailcones made for the 710/12 Pinzgauers and the that hitch will not fit the early tailcones. Plus they are made for an ATV which means it isn't suitable for for a road towing
I've had one of David's receivers on my pinz for a very long time and have used it to do numerous recoveries with straps, cables and receiver mounted winches. I even pulled a former grayhound bus MH conversion out of a ditch and hauled a 6500lb 35 foot long trailer "off-road" around my property - twice. Its super solid. I would go for the real deal and get David's.
The triangular plate has been by far the most common. Have seen a few made where the receiver tube was just butt welded to the plate, a big fail. The tube should puss through the plate and be welded on both sides. Some of the units did not fit if the body mounts were worn a little. Care should be taken when choosing the one you get. Sometimes cheaper is not always as good and vice versa.
boeing7873
Argentina
So... David, how much for one of yours?
Jerome
CRJ Driver
boeing7873
Argentina
By the way, I read there are two bolt patters on the tailcones, an early version and a new one. Anyone has the numbers? (Bolt pattern distances?)
Jerome
Jerome
CRJ Driver
boeing7873
Argentina
Here is another one...
https://www.ebay.com/itm/M998-M1038-HMM ... 2607915305?
Would this one work?
JC
Jerome
CRJ Driver
Hotzenplotz
Austria
Post by Hotzenplotz »
Jerome
there are two versions of that flange
v1 only has the 3 purple mounting points; v2 has 2 additional in pink
part no is 7101313720
a v1 flange is for sale in Slovenia
Albert
Interesting - I don't think I have ever seen a 5 bolt version before!
Hotzenplotz
Austria
I got that drawing from Magnasteye in 2012.
The sender remarked that the 3 bolt flange was produced until 1977, later versions use 5 bolts, but the spare part numbers were not changed.....
Albert
