Smaller steering wheel with power steering?
Posted: Sun Oct 29, 2017 11:37 pm
by GadgetPhreak
I just got my rig back from Andre, who did a bunch of work for me, including installing my power steering. All I can say is WOW! It's a completely different experience. I love it, and am looking forward to having it for snow driving later this year.
I'm finding that even on the lowest setting it feels like the size of the steering wheel is a bit large and could get reduced a little bit and fine tune the feeling some more.
Has anyone swapped their steering wheel out for a different model? I'm curious what others experiences have been.
Ben
Re: Smaller steering wheel with power steering?
Posted: Mon Oct 30, 2017 9:37 am
The Arizona crew used to cut the center out and mount it in a new smaller hoop
You can search it here but it was a long time ago
viewtopic.php?p=57796#p57796
PS rocks and I would be interested in a smaller wheel too but only if it looks more on the stock side of things.
Perhaps we have Andre weld up a couple?
Posted: Mon Oct 30, 2017 3:50 pm
by rmel
The advantage of sticking with the stock steering wheel is if your
PS unit craps out on the trail then you still have the leverage the
bigger wheel provides.
Posted: Mon Oct 30, 2017 6:44 pm
by 4x4Pinz
I built a few of the steering wheels. Just to clear it up the outside circumference did not change from the stock wheel. I still love the modified wheel even with my power steering unit. I was just asked this past weekend how a particular trail feel with the power steering compared to without. I honestly did not notice that I had power steering, it has become the norm for me and I can not or do not want to think of driving without the unit. All that being said I would not want to drive the truck with a smaller wheel if something went wrong with the steering assist unit.
Posted: Wed Nov 01, 2017 11:03 am
rmel wrote:The advantage of sticking with the stock steering wheel is if your
Good point!
Posted: Mon Nov 13, 2017 9:15 am
by Haf-e
I believe I've found a tractor which has the same steering column shaft as the 710/712 Pinzgauers - here is the drawing which I compared to the original:
- Pinz Compatible Steering Shaft.jpg (63.75 KiB) Viewed 10925 times
All of the dimensions appear to be an exact match - even the metric nut and taper on the shaft.
There are new 15 inch diameter steering wheel available for this model of tractor which are about $75 online - here is a photo of it:
- Pinz alternate 15 inch wheel.jpg (71.48 KiB) Viewed 10925 times
I will be ordering one to see if it actually works and will then let everyone know the model numbers etc.
There is a nice chrome center cap also - but it doesn't include a horn switch. Will need to figure that out still...
- center cap.jpg (11.51 KiB) Viewed 10924 times
Posted: Mon Nov 20, 2017 1:42 pm
by Haf-e
Well - the steering wheel I ordered doesn't quite fit - the splines are the same but the diameter is slightly larger so the wheel can just spin slightly.
Nobody I've asked can find one that works - even though the steering column shaft is identical to one that the USA manufacturer EATON / Char-Lynn offers with the code of "PT" in the part number - which is where that drawing is from. They seem to offer 4 different ends on the shafts though - and this one apparently isn't popular.
I did see that on Expedition-Imports site it says that the steering wheel used on the FLU419 SEE Unimogs fits the Pinzgauer - and they have a large one with thicker rubberized outer ring available:
https://expedition-imports.com/4064600203
MB Part Number: 4064600203
The listing does say there is a smaller version also used on the FLU419 SEE tractors???
Posted: Sat May 18, 2024 11:09 am
by LA_Pinz
Did you ever find an interchangeable part?
Posted: Sat Jun 01, 2024 12:53 pm
by Zee Fifty
There are companies and businesses out there that restore and customize steering wheels for the antique and collector car folks.
