The Series IIA FC launched in 1962 was based on the Series IIA 2.25-litre petrol engine and 109 in (2,769 mm) chassis, with the cab positioned over the engine to give more load space. Export vehicles were the first Land-Rovers to get the 2.6-litre petrol engine. Most examples had an ENV rear axle, a matching front axle came later. Tyres were large 900×16 types on deep-dish wheel rims to spread the ground weight of this heavy vehicle. These vehicles were somewhat underpowered for the increased load capacity (1.5 long tons or 1,500 kg), and most had a hard working life. Less than 2,500 were made, and most had a utility body, but surviving examples often have custom bodywork. With an upgraded powertrain, they can be used as a small motorhome.
Disc Brake Conversion Kits for 710 and 712 Pinzgauers www.klugewerks.com
Sorry but that is not a Series 2A/B Forward control - something else - maybe something home made or even a prototype. This is a 2b. The 2a looks similar but the headlights are mounted up higher on the body. The 2a was a 4 cylinder and the 2b was 6 cylinder.
FC 2b.jpg (67.12 KiB) Viewed 12098 times
Garry
1973 Haflinger AP700
1977 Landrover FC 101
2007 Range Rover Sport TDV6
1957 Landrover 88"
