Hi All
When reassembling the Half Axles where do I put the Loctite ?
Sam
Loctite
Re: Loctite
Repair manual calls for #270 green. This is high strength. However, I have been advised to use
Loctite -- Bearing retainer e.g. #609, from someone who has done MANY of these repairs.
A link for you here: http://www.loctite.com.au/3320_AUE_HTML ... 2648195073
Where it is applied is on the mating surfaces. There's a fair amount of surface area there so it will require
more than a "tiny" squeeze tube.
