Halflinger for sale $16,500.00
Beautiful Vehicle with new paint and Linex. The Haflinger is a small, lightweight, four wheel drive, high mobility vehicle about 3.5 m long and 1.5 m wide. --Powered by a 643cc flat twin horizontally opposed, rear mounted, air-cooled engine. -Weight: Just over 1300 lbs., -Haflinger can be lifted by four strong people and yet can carry a load of approx 1100 lbs. Off Road Features include: -Exceptionally low center of gravity due to the low placement of the chassis and the lack of upper body. -Generous approach and departure angles -The provision of both front and rear differential locks enables the vehicle to make progress even if only one wheel is in firm contact with the ground. -The 'portal' type design of the front and rear axles means that the center of the axle is above the center of the wheel, thus increasing ground clearance under the axle without the need to increase the wheel diameter. -Power is transmitted from the axle to the wheel via drop gears in each wheel hub. -The suspension is fully independent, of the swing axle type both front and rear, each half-axle having about 25cm of free movement. Thanks to Vince for this description. Find the pictures on www.racingjunk.com under the ad "Swiss Military Halflinger"
Re: Halflinger for sale $16,500.00
Direct link
https://www.racingjunk.com/Other/182990 ... =search#20
Pictures are poor quality but I think the whole thing is Line-X’d?
- 4ED20977-1E71-4B02-B7D8-37F9DE2D6F71.jpeg (97.87 KiB) Viewed 1613 times
