Scary lock-up on motorway
I was travelling on the motorway at 90 kmph in my Pinzgauer when suddenly the drive train seemed to lock up and I swerved into the fast lane missing a car by inches. Cars behind were also lucky to avoid an impact. It was scary! Thankfully, I managed to get her over to the hard shoulder.
At first she wouldn't budge, but after a bit of rocking, I found I could drive her in a straight line forwards or backwards, and was able to shift through all gears. I drove her off the motorway, but when I tried to turn on the exit ramp, I found I could barely steer her. I just drove her up on the grass verge and eventually got her towed.
Does anyone have any idea what happened? I had a look under the front and could see nothing obviously wrong. I didn't see anything broken or disconnected. What could it be? It was a hairy experience to say the least.
Re: Scary lock-up on motorway
Did the "lock up" make the truck swerve a lot, or just a bit?suddenly the drive train seemed to lock up and I swerved into the fast lane
Two scenarios come to mind: 1) the emergency brake was dragging enough to heat and engage more fully, creating the "lock up" condition. But since this is on the main drive shaft it should have affected both sides relatively equally, although locking the rear axle at speed will make the vehicle understeer (to put it mildly!). Or 2) One of the brake shoe's lining came loose and wedged up in that wheel; this will very obviously create a huge drag on only one side. At 90kph this would be expected to have horrendous effect if it happened on the front axle, less so if it happened on the rear axle.
If safe to do so, drive it around the block a few times at relatively low speeds (30-40 kph tops) and see if you notice heating of the parking brake area; this would point to #1. Pull the drums off all wheels and inspect the brake shoes, this will prove or disprove #2. Let us know what you find.
I would pull the drums off all wheels and inspect the brake shoes 1st before you do any more driving
- Hotzenplotz
engaged front locker ???
Albert
Albert
What do you mean by "seemed to lock up" exactly? Did the tires lock and leave rubber on the road? Did the steering wheel violently turn itself?
Thanks. The emergency brake and normal brakes were working fine afterwards, so not that. Maybe it wasn't clear in my post, but she drove fine after the incident, fine except I couldn't steer, so I'm starting to suspect the front diff.Two scenarios come to mind: 1) the emergency brake was dragging enough to heat and engage more fully, creating the "lock up" condition. But since this is on the main drive shaft it should have affected both sides relatively equally, although locking the rear axle at speed will make the vehicle understeer (to put it mildly!). Or 2) One of the brake shoe's lining came loose and wedged up in that wheel; this will very obviously create a huge drag on only one side. At 90kph this would be expected to have horrendous effect if it happened on the front axle, less so if it happened on the rear axle.
Maybe. Afterwards, it was driving fine but felt like the front diff lock was on.Hotzenplotz wrote:engaged front locker ???
The steering wheel did turn itself violently. And the Pinz lunged forward. I didn't look for rubber on the road, but it wouldn't surprise me it I left some behind!VinceAtReal4x4s wrote:What do you mean by "seemed to lock up" exactly? Did the tires lock and leave rubber on the road? Did the steering wheel violently turn itself?
Your locker cant just engage on its own but even if so, you'd have to be turning to some degree for that to cause a driving issue. In a mostly straight line, you can't feel it at all. I engage lockers on the road often, when driving straight, to exercise them after non use for a while.
If not the above brake issues, something is either loose, broke or is about to break somewhere in the driveline (front diff?)... that's my guess.
I once had a tranny go into 1st and 3rd as I shifted and it locked up the rear end (Econoline100 van). But this doesn't sound similar, since you can still drive it.
I'd jack up both front tires and see if they both spin the same direction (diff. locked) or not.
To me, this suggests the front differential locker is an issue, same as others have suggested. But it seems like an unlikely way to fail.Bermo wrote: when I tried to turn on the exit ramp, I found I could barely steer her.
Unless the diff "just failed" due to insufficient lubrication. Have you checked the fluid levels in the diffs? If they are low, drain them and inspect the diff bevel gears through the drain hole (let them drain for a long time so you can get under them with a light and look inside). Lift one wheel of each axle, have someone rotate that wheel while you are looking up the drain hole. Search for "execution II" to learn what should be expected to be seen for execution I and II, what the difference is, and why they created execution II. If you don't know what you are seeing, check out https://www.youtube.com/watch?v=G9wNbXZf6wU to learn how they work and best see what is in there.To me, this suggests the front differential locker is an issue, same as others have suggested. But it seems like an unlikely way to fail.
I jacked up the front axle and rotated one wheel and the other rotates with it, they are locked together. I activated the front diff lock and there was no change. I took it off again and still no change, the two wheels are locked together in rotation. The steering was fine, I did a full lock in both directions and the wheel could rotate, but in lock. So there is definitely a problem there. As a matter of interest, I jacked up the rear and that was fine, the wheels can rotate independently and rotated together when the rear lock was activated. I put the four wheel lock on and that worked as well. So the front diff if locked with the diff lock lever in the up position. So, I suppose I should investigate the front diff lock activation?
The front diff lock mechanism is much, much easier to check than a failed diff! But it won't hurt to drain the front diff and look for metal pieces, too; that is also not difficult. One or the other should tell you what happened.
The diff lock coming on would not cause the symptoms you described of it locking up on the motorway. I suspect there is something more going on such as failed bearings. Draining the diff is the first step.
Hopefully its something like the spider gears locked up. Still requires pulling the front diff assembly.
So I can actually think of a way this violent jerk left could happen in the case of the front diff lock engaging on its own. If you have the front left tire underinflated, overworn, or any other condition that would make its effective diameter smaller, when the axles locked, it would begin to pull left. I'm not sure it would be violent, or even noticable, under normal conditions but in excess, could become violent. Not totally sure here... Even if there is a smaller diameter on the driver side, it wouldn't explain the condition of driving straight just fine and locking up when turning... unless you're fighting a wheel trying to move slower, but I doubt you could hold the steering wheel enough to slow the vehicle. That'd be an overwhelming amount of force.
Just spitballing ideas, this is weird for sure.
1977 Austrian 710M
