Trailer cable and plug
12N plug with 6' of trailer wire. This is the typical plug for Swiss and civilian Pinzes.
I had made this for my 716 to adapt to any other trailer. Since The Pink Cow is long gone, and almost everything else I have is NATO, there is no reason to keep it .
Nice HD insulation on the 7 lead cable. $35 plus postage
EmbarkChief
Re: Trailer cable and plug
Post by EmbarkChief »
I’ll take that action. Is it ok if I pm you details tomorrow?
-1972 710M
That'll be fine
The attached pdf is the wiring for the 12N and NATO ( if you ever need it)
Swiss Pinz use 4 pins, Austrian and all other use 5 ( separate pin for brakes)
NATO and 12 N socket.pdf
(157.19 KiB) Downloaded 300 times
EmbarkChief
Thanks! I’ll be in touch
-1972 710M
