4 bolts on the nose/hood?
AZ_Mike
Post by AZ_Mike »
I'm very curious about the pre-existing bolts and rivet nuts located in various places of my 712 body and what their original purpose was.
I'm particularly interested in the four bolts on the front of the vehicle. They appear to be 8 mm bolts with 13 mm heads spaced 10 cm vertically and 100 cm horizontally. They are offset significantly towards the passenger side. The bolts going to nuts with reinforcing plates under the dash and in the glove box. What was the original purpose on the vehicle?
I am thinking they would be excellent mounting points for a hi-lift jack mount.
New owner of Swiss 1975 712AMB.
Re: 4 bolts on the nose/hood?
sounds like you are describing the antenna storage mounting locations.
pinz front.jpg (146.68 KiB) Viewed 4644 times
oh and yes I like the jack in that locations
parade pinz.JPG (64.65 KiB) Viewed 4643 times
AZ_Mike
Post by AZ_Mike »
Thanks to both of you. I think that is what I'll be doing. I better buy the jack first as that area is going to get a bit crowded. I was planning on putting 2 20 inch light bars on either side of the windshield washer nozzle.
