New front brakes (part 2)
For some reason I can only post 5 photos, so here is a continuation of the brake job.
IMG_0896 - Copy.JPG (338.11 KiB) Viewed 5830 times
New booster and the original from 1974. I had to move the brake rod attachment from old to new.
IMG_0900 - Copy.JPG (275.87 KiB) Viewed 5830 times
New booster installed. Time for a beer! I replace the reservoir tank while I had the chance, the old one was pretty beat up.
IMG_0898 - Copy.JPG (404.67 KiB) Viewed 5830 times
Getting ready to assemble the wheel cylinders after everything was cleaned up. I used a 13mm socket in a vice to hold the piston still while I installed the seal. So easy that a caveman could do it! Note- none of the cylinders needed honing.
IMG_0899 - Copy.JPG (691.28 KiB) Viewed 5830 times
2 assembled cylinders ready to be installed. I also did the left side, so all 4 were done at the same time.
IMG_0890 - Copy.JPG (343.41 KiB) Viewed 5830 times
Time to put the puzzle back together, which was surprisingly easy. Note- the cylinders are not the same, one is a mirror of the other.
