Small gauge size in dashboard
Jake2015
Post by Jake2015 »
I’m looking to add a gauge to an open position on my dash. When I remove the plastic cover and measure the hole it seems to be 60mm, or just over 2 1/3”. I see gauges with bezels of 2 1/4” but nothing larger until you get to over 3”. Has anyone installed into the smaller holes and what size gauge did you use?
_________________
1977 Austrian 712K
http://www.swpinz.com
Facebook: Southwest Pinzgauer
Hotzenplotz
Austria
Re: Small gauge size in dashboard
Post by Hotzenplotz »
Jake
The Pinz is metric. The hole in the dash is exactly 60 mm in diameter and in previous years this was the standard size for several gauges.
Some folks have installed Voltmeters to display the status of the onboard electricals, others have added a second fuel tank and use this hole for the corresponding gauge.
VDO nowadays offers most of these devices in 50 mm diameter, and you can purchase an adapter ring for 60 mm holes with them.
hope that helps
Albert
I've posted this before but easy to get lost in obscurity.
VDO reducing ring: 2 3/8" to 2 1/16" PN# 600-851
https://www.summitracing.com/search?Sor ... ord=600851
Jake2015
Post by Jake2015 »
Thanks for the information and suggestions. I ended up talking to a friend who has a CNC plasma cutter and got some adapter rings.
_________________
1977 Austrian 712K
