Fan pulley Nut?
waterdog
Paraguay
Fan pulley Nut?
Post by waterdog »
Hello folks... does anybody knows and tell me the size of this nut holding the fan pulley... to replace the belt??? And its a regular side thead correct??? Thanks in advance.!! I just need to take it with me in my tool box before get to the vehicle...
1985 710MS
1985 712MK
Re: Fan pulley Nut?
Although a standard thread M14x1.5 and hex head 27mm it's a specialized
nut with a flange to apply proper force on the "pulley halves". You'll need
the proper nut for this.
waterdog
Paraguay
Re: Fan pulley Nut?
Post by waterdog »
Yeah, i have the tool to hold the pulley, im not shure about the size of the socket to remove the nut...im not replacing the nut,, i just need to remove to replace belt
1985 710MS
1985 712MK
Re: Fan pulley Nut?
27 mm metric, or 1 1/16" SAE.
One of the few metric = SAE cases; 3/4, 15/16, 1 1/16.
Also note the fan nut is standard right hand thread. Also
note the torque is ONLY 67 Nm don't over tighten.
