Fan Nut Threading
Tomaboyd
Fan Nut Threading
Post by Tomaboyd »
Is the fan nut normal or reverse threaded?
Mine won’t budge either way and I would like to know before I start applying max pressure.
Thanks.
newtopinz
Re: Fan Nut Threading
Post by newtopinz »
Should be normal threaded. If you look at the fan blades and how it should rotate, it is clockwise rotation when viewed from the front.
Standard right hand thread -- clockwise.
A common issue that some have done is over-tighten, MAX torque is 67 Nm (49.4 ft-lbs).
Some has thought it was a left-hand thread and thus over-tightened.
It is also somewhat awkward to remove this nut without the fan locking tool. If
you don't have that get one or make one. It makes a big different it being able
to get leverage on the fan without putting stess on the fiberglass blades.
Tomaboyd
Post by Tomaboyd »
Thank you. I do have the tool. I even enlisted the help of a friend and we could not get it to budge. Today we will try an impact gun and/or cheater bar. Just wanted to make sure I was pulling the right direction.
Thanks again.
ChickenPinz
Post by ChickenPinz »
I just loosened mine for the first time, and like yours, it was crazy tight. But using a pneumatic impact wrench with a tight fitting six-point socket I was able to get it loose. Will definitely use a torque wrench for reinstallation.
710K
djw
Post by djw »
The first time I removed mine I had to use a little butterfly air wrench as it fit nicely in the space. The nut was a bit rounded when I got the truck. A couple of short blips and it was free and correct since.
I figure the Austrian military kid that last tightened it had a lot more muscle than me.
lifefloat
Post by lifefloat »
I think the same Austrian military guy overtightened my fan nut too!!!!.
Finally got it to break free using a cheater.
I put a dab of never-seize on it since then and it isn't and issue now.
Recently I had to take my fan off to get a rat nest out of the air space on top of the cylinders. Fn rats.
The rat chewed up a spot or two on the fan also. Due to the fact this is a balanced piece, I have since replaced my fan. I now have a slightly chewed spare. Not sure if this was an over reaction on my part to replace the fan but I do not ever want a fan to grenade on me. I've read some horror stories about that happening.
