Truck won't start
ziegler
Truck won't start
Post by ziegler »
She started yesterday, ran for about 10 seconds then stopped. I tried to start her up again but she just cranks. Any suggestions are welcome. Thank you. ZIg.
whitesik
Re: Truck won't start
Post by whitesik »
Don't want to skip the obvious; fuel in tank? :D
75 Swiss 710K
W9YG
Hugues
Post by Hugues »
as stated above,
and to be sure fuel reaches the combustion chamber, remove the air intake, depress the accelerator, you should see/smell fuel being injected.
Then if ok, check you have sparks on your plugs by removing one and grounding the thread, (google this if you are not familiar with this procedure).
Hugues
From Switzerland
ChickenPinz
Post by ChickenPinz »
...also, check fuses/breakers.
Check that the shutoff solenoids at the carb bases are powered. A wire could have failed
The Pinz is a simple caveman engine. You need spark and something for the spark to ignite (gasoline vapors).
710K
