Batteries
Posted: Mon Aug 04, 2025 7:45 am
by ziegler
One of my batteries is 12.7 volts and the other is 11.5 volts. The engine cranks but won't start. Will the battery under 12 volts prevent it from starting? Thank you.
Re: Batteries
Posted: Mon Aug 04, 2025 7:57 am
by whitesik
It is possible. If those voltages are after charging, then the 11.5v did not take a full charge and is probably bad. Cranking voltage would be even lower.
Re: Batteries
Posted: Mon Aug 04, 2025 10:49 am
by rmel
Here comes 1,000 questions :shock: :lol:
What type batteries do you have: Lead Acid or AGM.
AGM @ 11.5V is a 10% charge.
Lead Acid is essentially dead below 11.5V
Which battery is at 11.5V, bottom or top?
Try charging your batteries individually with a 12V charger.
That weak battery may NOT take a charge and bad cell(s) -- but worth a try.
Are you running with the stock ignition or aftermarket?
If aftermarket, Pertronics or PinzSSI (what version)
Re: Batteries
Posted: Mon Aug 04, 2025 4:33 pm
by ziegler
Lead acid batteries with PinzSSI. I will try to trickle charge the battery closest to the tool box that's at 11.5.
Re: Batteries
Posted: Mon Aug 04, 2025 4:37 pm
by ziegler
I'm running the optima 3478 batteries. IF the back battery is dead, can I run a new AGM optima with the other lead acid battery? Or is this a no no.
Re: Batteries
Posted: Mon Aug 04, 2025 4:46 pm
by rmel
Can't mix and match Lead Acid with AGM, won't charge balance correctly.
For that matter you really need to have both batteries identical and the
same age. Even still charging won't be perfect.
I asked about that ignition your running as you implied the engine was
cranking -- with the stock Ign you probably would have started. So I got
suspicious you had some form of SSI. The early PinzSSI's (1.0) were vulnerable
to lowish battery voltage.
Re: Batteries
Posted: Tue Aug 05, 2025 10:41 am
by ziegler
Thank you very much for your input. Time to buy 2 batteries and listen to the wife complain for a couple of days. It's worth it, I love my Pinz! This will be the third time in 21 years I've replaced the batteries.
Re: Batteries
Posted: Tue Aug 05, 2025 10:54 am
by whitesik
On a little side note and out of curiosity, if one was on the road and had this problem, could an external 12v source be applied to the PinzSSi just to get the vehicle started. The PinzSSI runs from a 24v to 12v DC to DC converter. Would bypassing the converter work? If even directly from the one good battery? Perhaps I am crazy here.
Re: Batteries
Posted: Tue Aug 05, 2025 10:55 am
by whitesik
Ah ,, forget it. There is that starter thing.
Re: Batteries
Posted: Tue Aug 05, 2025 5:25 pm
by rmel
It's a good question Keith. And all depends upon the PinzSSI version.
The 1.X generation was the most vulnerable to the quality of the
24V source. The fist incarnation took power for the Coil pack and
the Module from the bottom battery, so if that was low and while
cranking even lower you could be in a situation where there was
insufficient voltage for the module to work and thus no trigger
to the coil pack. There was a tweak on the power delivery scheme
for the 1.x generation but that too could be exposed to low 24V.
The 2.0 and later versions added a Eaton DCDC converter which
pretty much eliminated the issue -- as long as the 24V didn't go to
too much below 18V.
So...if one is stuck in a situation where the battery is near dead,
but you can crank but no spark....it's jumper cable time. Or
if your lucky on a steep grade to pop the clutch.
Re: Batteries
Posted: Tue Aug 05, 2025 7:43 pm
by whitesik
Thanks Ron as always. I just wondered. I usually have a couple 12+v batteries with me for radios that may power the pinzssi but not be good for cranking.
Re: Batteries
Posted: Sat Aug 09, 2025 9:00 am
by Stumbler
This entire discussion seems a little derailed.
A battery can throw 11.5 volts, or even 12.x, on a standard voltmeter and not be able to crank an engine. It's the amperage that counts most. If the battery is bad, and not showing obvious signs, the only real way to test it is under load. The starter pulls an immense amount of energy and that's hard to duplicate on each battery in a Pinz since they are run in series. Since you can't try it with one and then swap them out and test the other, the simplest and easiest way is just to take the batteries out, clean them up, put them on the charger until you think they are fully charged, and take them by your local Autozone. They will put them on their meter for free. (And it's a different meter than a simple voltmeter, is has a resistance load of 50 to 100 amps) They can tell you within reason if the batteries are fine, need help, or dead.
On a side note: The way Styer run the batteries in series and charged them is inherently wrong. It was the technology of the time. It always results in one battery charging or discharging a tiny bit faster than the other. Some people use an isolator to help fix this. Personally, I just put the battery charger on them about every 6 months and let the charger desulfinate and top off the charge.
Re: Batteries
Posted: Sat Aug 09, 2025 9:20 am
by rmel
Ya, series batteries is not ideal.
I do swap the positions on occasion and regularly charge then
You can test these yourself, with a load tester, they are fairly inexpensive.
https://www.amazon.com/dp/B07Z67MMGC?re ... n_title_24
Re: Batteries
Posted: Sat Aug 09, 2025 5:56 pm
by ChickenPinz
If you run standard lead-acid batteries, it's perfectly fine to charge them like the Pinz does in a series configuration. But there's a key rule to that: The batteries MUST be matched. That means replacing them as a set with the same batteries at the same time. That's going to give you the best overall life and performance.
Remember that each "12V" battery is a collection of six "2V" cells. Connecting up two just makes that a stack of 12 count of 2V cells.
Now, if you do things like take 12V taps off your system, that unbalances it. Luckily, the lead-acid chemistry is pretty tolerant and will mostly absorb the difference and sort it out. Mostly. But it's going to put extra wear on the battery you're not drawing power from because it's going to get more overcharged to get the loaded one charged up.
But.....if you go to lithium-iron-phosphate, the game changes. In those batteries, they run cell balancers internally. My advice is if you want to use that chemistry and want to use two "12V" batteries stacked in the Pinz (or any other 24V system), then you need a balancer. They make them. You're looking at things like this https://www.aliexpress.us/item/32568091 ... 4itemAdapt but I'm just linking that one for reference. You can also use these for your normal lead-acid systems.
But be careful and check what the parasitic load is when the charging voltage is off. One thing I LOVE about the Pinz is when you turn it off, it's completely OFF with zero drain on the battery.
Me? I'm going to stick with lead-acid in the Pinz. The extra weight helps smooth the ride, and there's no BMS in the batteries to fail me in the middle of nowhere. And lead-acid batteries are much more forgiving to injustices.
Re: Batteries
Posted: Mon Aug 25, 2025 9:46 pm
by VinceAtReal4x4s
Any possible issues using this on my two 12v NATO batteries in the Mog? I was tired of swapping my trickle charger over and got one of these 24v versions a while back (via a heavy discount on ebay)
