electric fuel pump installation
michaelh712
Post by michaelh712 »
I know this has been covered, but now lost.
I'm considering installing an electric pump in hopes it will cure my stalling problem. Where should I take off for power, and do I need some sort of pressure regulator? It is a 24 v pump for a cucv truck.
Thanks, Michael
Michaelh712
michaelh@updc.org
Educational Anarchist
get your power off some ignition switched point. You will probably need a regulater to get pressure down, and do not forget to put either an inertia or a oil pressure switch inline to shut the fuel off in case of an accident or other misshap... you do not want the fuel to keep pumping when the engine is off.... no es bueno!
Dave Dunn
michaelh712
electric fuel pump
Anyone have a 24 v electric pump installed? If so, I'd like some specifics about a regulater if needed and some sort of safety shut off.
thanks
Michael
Michaelh712
michaelh@updc.org
