Those that have changed over to ExecII was it because of a mechanical breakdown, or just because you were getting into the Diff for other reasons. Have you noticed a change?
To upgrade do you just do the front or front and rear? With a 712 thats $1500.00 just for the parts
Those that have had a breakdown of the suspect parts in the Diff, what was the cause. Low fluid in the Diff, Harsh offroad use / excessive torque, high mileage?
I'm trying to decide if I am going to remove the body to do a full body off restoration. If I do I might go ahead and do the ExecII upgrade. I just am not convinced that it is needed. So I am trying to find out the numbers of failures verses the number of people that have had no problems with thier Pinz', and have put some miles on them.
Miles
