Has anyone had double bead lockrims made-up for the Pinz? I called USA 6X6 and the cost seems prohibitive.
Chuck
Double bead lock rims
The staun bead locks lock both sides of the tire using the stock rim. They come in the Pinz size (16 X 6.5). At 175.00 a pop they are in my opinion relatively inexpensive as they also work as a run flat, require only one extra hole to be drilled in your rim and are DOT legal. Here are a few links.
http://www.staunproducts.com/beadlock.php
http://www.4wheelparts.com/4wp/products ... ccessories
Bernhard
1975 710K
2013 Tacoma TRD 4X4
1975 710K
2013 Tacoma TRD 4X4
