VDO Electronic speedo install
Hawkeye Pinz
The original VDO speedo in my '73 710M isn't working all of the time, so I want to install an electronic speedo. How many of you guys have done this mod/upgrade, and is it difficult do do? Let me know of any bumps in the road you may have come across! Thanks in advance for the pointers
The installation is fairly straight forward. The easiest way to calibrate it is with a mile already marked off. If you change tire size, you just need to run the mile again. I've done 3 Pinzes and a Haf this way.
Dave Dunn
Dave Dunn
Lightningpinz
I agree with Dave it is straight forward and easy to do. I believe Patrick at CWRI's kit comes with a cable that locates the sending unit behind the dash, and most every other kit you install the sending unit on the top of the speedo drive on the front differential and run a wire to the new speedo unit. I could be wrong on CWRI's since I haven't installed on of their units in a while.
A measured mile works great for calibration, the unit is also set up for using a gps to modify up or the speed setting after you get it set. I LOVE MINE.
Hawkeye Pinz
Electronic speedo
I have been thinking about this mod but I have not seen any digitals that have the trip setting like the stock speedo. I may just take mine out and replace the glass and it will look like new. Is it possible to calibrate the stock one for the 33 inch tires I am using. MMMV
Morris,
710M
Morris,
710M
digital speedo
Thanks to Dave & Ron for the answer on the trip ODO, that helps the decision process. Does the speedo from SAV just plug and play or will I have to 'adapt' it to the 710M? Does one out there, in that price, range just P&P?
My speedo works ok just taxes the mind to keep translating from kmh to mph. I just take the first number in kph drop the 0 and multiply by 6, real close to reality.
Or....oh, where can I get a stick-on mph decal?
Morris
Morris
Morris,
Some of the 710/12s did have labels on the speedos for miles.
SAV's kit is a metric sensor. But the last 2 I did on the Pick Cow and my Haffy, I used the pigtail..
As far as P&P, you still need to do the calibration, which is very simple.
As far as I'm concern, none of the original speedos are correct. Some don't give the right speed, odometer are off or broken, tripmeter are broke, or the speedometer doesn't work... not to mention, once you change tire size, well ,you know..
Dave Dunn
Dave Dunn
Lightningpinz
The last SAV speedo's I installed are "P&P" Then calibrate. The speedo adapter/transducer mounts on the speedo drive on the front differential and then run the cable to the speedo head and hook up wires as shown in the installation papers. Wire hookups are 2 lights in the gauge from the old one in the old speedo, an ignition power ( grab from breaker #12) and the wires from the cable supplied in the kit. So the only adaptation is hookup of wires that the original speedo didn't have since it was cable driven.
Best of luck.
Best of luck.
And don't forget, most of the Swiss Pinzgauers have a right angle drive on the back of the speedo that forces an error in speed. At least removing the right angle drive improves the accuracy of the speedo.David Dunn wrote:Morris,
<snip>
As far as I'm concern, none of the original speedos are correct. Some don't give the right speed, odometer are off or broken, tripmeter are broke, or the speedometer doesn't work... not to mention, once you change tire size, well ,you know..![]()
Dave Dunn
By the way, you can have a speedo shop make a reduction drive so the stock speedo actually reads 0 to 100MPH instead of 0 to 100KPH if you want to keep a totally stock look. About a 1:0.61 ratio would work.
Ron Schroeder
WD8CDH
'73 710M
WD8CDH
'73 710M
