Hi all,
This is another hub oil related question.
The oil suggested by the factory for the turbodiesel Pinz hubs is Mobil
Glygoyle 30. It appears that that oil is a top grade carter gear
lubricant for extreme pressure and heat industrial applications; also,
it offers outstanding rust protection.
But - it is tremendously expensive !!!
Does it offer any REAL advantage on an automotive grade 75W90 or 80W140
gear oil? Is it advisable to use it on a gas Pinz?
On the other side - can an automotive grade gear oil be used on a TD
Pinz instead of the Mobil Glygoyle 30?
Ugo
1977 710M
1990 716K
Torino, Italy
Glygoyle ???
The true Pinzgauer´s
