O.D./Infra Red paint
Is there a specific formula or paint number for the standard O.D. paint used on the Pinz? Sources or other tid-bits appreciated.
Wayne Roberts
2012
Twin Pinzies
Not really needing the Infra Red capabilities, just the color match.
I guess I will take some removable item from the truck to my friend who does paint at the local hardware store and see what he can come up with. Got some areas I want to treat with POR-15, then paint over. Thanks for the replys.
1975 710M
Here's a link to a place that sell several military colors mostly US stuff thou: http://www.avettruck.com/Featured_Produ ... e_pai.html
Just get in and go....
Check out Rapco parts. They have the CARC style paint you are looking for. I have had good luck with all the paint I have purchased. They will let you mix colors for a full case price.
http://www.rapcoparts.com/sigaofpa.html
Swifty 72 710M
Could some one explain the purpose and function of the Infra Red capabilities of the paint. Is it to adsorb the infrared or reflect it?
2012
[quote="kc4mne"]The Pinz Color is RAL 6014 (Yellow Olive)
You can go to a sherwin williams chemical coatings paint store and have them mix it in quick dry enamel in a satin finish.
OK, but the folks at my local S.W. store looked at me kind of funny when I asked about "RAL 6014". Turns out the RAL is a European color standard.
The S.W. folks said they could match a color (give 'em an appropriate part with said color) but as for actual color number that is unknown. They also said the automotive division would be able to produce a much more "robust" exterior paint for re-painting exterior surfaces.
So, another trip with a sample may finally give some formula for RAL 6014, Yellow Olive (Flat O.D.)...
1975 710M
