Timing
Posted: Thu Jan 11, 2007 7:48 pm
by Boelt63A
I have a civilian distributor and pertronix set up. Question is Do I disconnect the vacuum advance on the distributor to adjust the timing or leave it alone?
Also the truck seems to run a bit better with almost 10 degrees of advance, is this too much?
Chuck
'74 710M
Posted: Thu Jan 11, 2007 8:34 pm
by Jim LaGuardia
Ther eis no vacuum advance, that line removes moisture from the distributor.
A lot of guys run up to 10 deg btdc
WOW
Posted: Fri Jan 12, 2007 5:57 am
by Boelt63A
Jim you have no idea how helpful that was!!
I have had terrible problems with condensation in the cap. I've had to all but rebuild the distributor due to rust in it. I bet that line is plugged somewhere. Just in time for a weekend project!!
Chuck
710M
Posted: Fri Jan 12, 2007 9:14 pm
by ExpeditionImports
In the rubber 90 degree elbow of that line there will be a brass jet...more than likely it is clogged. Do NOT completely remove it.
Scott
Posted: Sat Jan 13, 2007 1:10 pm
by Boelt63A
It is, and I was wondering what it was. Luckily I haven't totally torn it apart trying to get it out.
Any advice on ho to clean it out?
Chuck
'74 710M
