LED LIGHT BULBS
Posted: Tue Mar 13, 2007 9:58 pm
by ms1223
Has anyone tried these LED light bulbs?
http://www.superbrightleds.com/other_bulbs.htm
I'm having a hard time finding 24v bulbs. I need some replacements and some spares. I had to "borrow" one today from my 416 trailer.
Posted: Thu Mar 15, 2007 9:13 pm
by goudacheese
I am using the 1156 19 LED White for the front & Yellow for the rear. I am also using the 1156 White LED's for the inside spot lights in my 710K. The 12 LED bulbs are not that bright.
Posted: Thu Mar 15, 2007 9:57 pm
by ms1223
I think I'm going to try some in my M416 trailer. I hope this will keep the amperage down and the stress on the Pinz wiring Last year I burnt everything associated with the Green/Black tail light wire including the turn signal switch.
Posted: Fri Mar 16, 2007 10:20 am
by pinzinator
Mr Cheese- Did you use the wide angle bulbs (100 degree vs 12)? And as for the red LEDs, did you use the brighter '19' version? I am curious because I would like to order some for my Pinzgauer.
Posted: Fri Mar 16, 2007 9:25 pm
by goudacheese
I don't know what degree the bulbs are but they look like the LED bulbs that ms1223 referenced. I am using the 19 LED Amber bulbs in the front parking lights and in the rear Hella turn signal lights that I added. Tail lights are already LED.
I found that if I use LED bulbs in both the front & rear turn signals they will not work, but if I use just 1 LED and a regular bulb the turn signal works.
