Do you use first gear?
Unloaded truck, flat ground, normal conditions. Or do you just start off in second gear? I did this years ago when I drove single axle dump trucks (empty) for as summer job. Just don't want to wear the clutch any more than normal.
either
Todd, a clutch disk from dennis is right around 100 bucks. I changed it in less than a couple hours and I didn't even know what I was doing. Pretty much don't worry about it. I frequently started in second. I frequently started in first. Sounds like you might have to start the engine in first for awhile with that knee!
Regards,
Bryan
Regards,
Bryan
6 X 35" tyres, 710 transfer case and usually loaded for a trip (140 litres fuel etc) .... Hmm, I need to use first gear to get off the line and save the clutch!
I can get off the line in second, but why stress the components .... it's there after all and it doesn't cost extra to use it!
1997, 718 6X6 Pinzgauer
first gear?
I used it when I first got it, then morphed into using second to begin around town. In the desert or the rocks or loaded it seems to work better starting in first. With the transfer case and first in the desert it really takes hold.
Morris
Morris
Re: either
Been having to start her up while standing outside for now.75pinz wrote:Todd, a clutch disk from dennis is right around 100 bucks. I changed it in less than a couple hours and I didn't even know what I was doing. Pretty much don't worry about it. I frequently started in second. I frequently started in first. Sounds like you might have to start the engine in first for awhile with that knee!
Regards,
Bryan
Protoman333
ive found that in parking lots, its fun to go into low range and shift like mad. the look on peoples faces when you are in 4th going 10 is gold. of course ive driven around with crappy, if not barely functional, brakes for 3 years of my 7+ year ownership so that type of driving is mandatory in a parking lot (compression braking) to be safe(er).
other than that, i have to be pretty loaded down to use 1st.
and holy s**t, mjnims! 28 bags o' crete?!! we have a winner!
Chris
'73 710m
'73 710m
I use first gear every day as well as all the other gears, as a tranny specialist I have to say there is a lot of paranoia in this group lately.
Just use common sense and you won't break anything, after all these are "extreme off road vehicles" and quite overbuilt at that.
As for extra clutch wear, it's all in how you use it
jacksonpinz
goudacheese
Bruce Berger
