Steering
jacksonpinz
Steering
Post by jacksonpinz »
Can the seal at the base of the steering shaft where the pitman arm attaches be fixed by just pulling the pitman arm or do you have to remove the whole steering assembly?
If you are lucky enough to own a Pinzgauer, then you are lucky enough!
pinzdriver
steering seal
Post by pinzdriver »
just pull the pitman arm :o
tony in az 73 pinz 6X6
pinzdoctor is the name,pinz repair is the game!
jacksonpinz
Thanks!
