Replacement fuel pump
Posted: Sun Apr 15, 2007 10:02 am
I found a replacement fuel pump that drops right in and works fine. All you need to do is rotate the upper housing 180 degrees before installation so the fuel lines line up, which takes about 2 minutes. The inlet/outlet tubing is the correct diameter. I run this in my Pinz with no problem, and keep a rebuilt OEM pump as a spare. http://amazon.com/s/ref=sr_pg_2/002-435 ... ley&page=2 Just scroll down to item #48, pump number 151-6753.
