Replacement fuel pump
I found a replacement fuel pump that drops right in and works fine. All you need to do is rotate the upper housing 180 degrees before installation so the fuel lines line up, which takes about 2 minutes. The inlet/outlet tubing is the correct diameter. I run this in my Pinz with no problem, and keep a rebuilt OEM pump as a spare. http://amazon.com/s/ref=sr_pg_2/002-435 ... ley&page=2 Just scroll down to item #48, pump number 151-6753.
Thanks for the info, I have one of those but have not tried it yet. Glad to hear it works. My only concern was that, on mine at least, the rocker cam hangs a little lower than the stock OEM part.
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
