Tire Balancing
Tire Balancing
Just a quick question. Has anyone tried "on the truck" tire balancing. I know a few of these older machines exsist, where they can spin the tire on the car or truck. Can anyone think of any negatives in terms of balancing the pinz tires using this method?
Thanks Tod
Thanks Tod
Tod Guenther
P.O. Box 1371
Hood River, OR 97031
P.O. Box 1371
For the few who really know how to use these, they work great. The added plus is it also includes any rotating mass ( drums,axles,brngs)in the process. the down side is rotating the tires will undo this,and you must also reinstall the wheel with the studs in the same holes each time.
Mark
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
68 Haffy
turn signals and backup lights
Sounds much, much too complicated for practicality.
Try these people, call them with questions. http://www.innovativebalancing.com/index.html
I have had them in my tires for almost 8 months and they seem to be working for me and no annoying weights to drop off on the trail. No odd wear either. I am running BFG Mud Terrain 255/85/16 which seem good on and off road.
Morris 710M
Morris 710M
Thank's for the thoughts guys. I think I'll proceed down the road that "krick3tt" recommended. Seems pretty simple and it's nice to know that it's working for someone.
I have an old 240Z that I've always used "on the car balancing" for the front two tires and it works great - no comparison! But given the differential comment I don't think I'm willing to give it a try on the pinz.
Thanks again
T
Thanks again
T
Tod Guenther
P.O. Box 1371
P.O. Box 1371
tire balancing
todg
When you order the stuff, get the installation goodies. There is a 'kit' for a few dollars that is worth the bucks. Be sure to get the valve stem inserts.
Take the tire off the truck, down flat on it's side and it will be much easier to insert the beads with the tube.
I seem to remember getting the 8 oz beads, but be sure to ask them for the correct weight for your use and tire size, as it may not correspond to the chart on the webpage.
They are very helpful people.
Morris
Morris
Protoman333
tire balancing
Sure.
My tires were already mounted on the rims.
'Just throwin' the suckers in there' is the simple route, probably preferred if one is putting on new tires.
Morris
Morris
Pinz Enthusiast
Tire Balancing
Im with Morris an dinovative balancing, I've been using their stuff for about a year now and am very impressed, had a little bit a shake and shimmy at highway speeds, dropped in 8oz of their beads and it's smooth as silk, even after having my tires removed and flipped on the rims, they lost very little product, one thing though don't carry any type of fix-a-flat or the green slime as it causes the product to clump, so thats not good. pretty reasonable too, only cost me like $75.00 for my 712, Im sold on them.
Eric
Anaheim Hills, Ca
1996 LR Disco I
2003 LR Discovery SE
hope to get a 1969 Ford M656
Anaheim Hills, Ca
1996 LR Disco I
