Wheel Seal
jacksonpinz
Wheel Seal
Post by jacksonpinz »
I have a leaking wheel seal and was wondering if I have to order one from SAV or if I can get a match from NAPA. Thanks
If you are lucky enough to own a Pinzgauer, then you are lucky enough!
lindenengineering
Post by lindenengineering »
Wheel seal??
Are we refering to the hub seal or wheel cylinder seals?
The hub seal COULD be available off the shelf if the Napa store in question has a comprehensive range. More likely you will need to consult a bearing/seal specialist, CR does have seals to fit.
Remember depending upon build condition two different seals are installed in the Steyr hub, they are not interchangeable and you will only find out which one you have by tear down.
The brake cylinder seals are a big "Doubtful". You might get them from a Tieves agent but its more likely you will need a factory part for that repair.
Dennis
OOOps no customer bashing now
Erik712m
Post by Erik712m »
Seals can be order from the kok web site as well
Kiwibru
Post by Kiwibru »
Sorry for my question but who is KOK?
1975 710M
Erik712m
Post by Erik712m »
[http://www.oilseals.net/] here you go[/url]
