Wheel Seal
Posted: Fri Jun 01, 2007 8:13 am
by jacksonpinz
I have a leaking wheel seal and was wondering if I have to order one from SAV or if I can get a match from NAPA. Thanks
Posted: Fri Jun 01, 2007 8:28 am
by lindenengineering
Wheel seal??
Are we refering to the hub seal or wheel cylinder seals?
The hub seal COULD be available off the shelf if the Napa store in question has a comprehensive range. More likely you will need to consult a bearing/seal specialist, CR does have seals to fit.
Remember depending upon build condition two different seals are installed in the Steyr hub, they are not interchangeable and you will only find out which one you have by tear down.
The brake cylinder seals are a big "Doubtful". You might get them from a Tieves agent but its more likely you will need a factory part for that repair.
Dennis
Posted: Fri Jun 01, 2007 11:50 am
by Erik712m
Seals can be order from the kok web site as well
Posted: Fri Jun 01, 2007 2:45 pm
by Kiwibru
Sorry for my question but who is KOK?
Posted: Fri Jun 01, 2007 6:27 pm
by Erik712m
[http://www.oilseals.net/] here you go[/url]
