All,
While I have my truck down for maintenance and upgrades I wanted to mount a pair of TD tail light units. They only take two bolts but the flange on the left side where the tail light is mounted has an unused cup behind it and one of the TD tail light mounting bolts will come out inside the cup. Is there an easy way to remove the cup or is my best option to just cut a hole in it with a cut off wheel to get the nut on it? I'm concerned about it collecting dirt and water.
Has anyone else come up with a good alternative solution for mounting TD tail lamps?
TD Tail Light Mounting?
Bruce Berger
Bruce Berger
'72 Pinzgauer 710M 2.6i
gunipinzmutt
Bruce,
all Austrian army gas pinzies have the TD back lights, but they have been modified with TD mounting plate. I have mounted a couple of Fiat Daily lights. If you like I could send you pics of both.
Ciao
Gunipinzmutt
Ciao
Gunipinzmutt
Pinz: 710 m, 710 ms, 710 k, 712 m fla, 712 k, 716 m, 718 m san, 716 k, 718 rehinbraun
Haflinger: 700, 703
G: 250, 270, 400, 350
Unimog 406
M825, M151 A2, M416
Fiat Panda 141A 4x4
Fresia F18
Haflinger: 700, 703
Unimog 406
M825, M151 A2, M416
Fiat Panda 141A 4x4
Fresia F18
