gas guage not working
norcal pinz
Post by norcal pinz »
hi all, my gas guage is not working ,how do i test it .right now i have the gas tank off and i can easily get to the sending unit any help will be appreceated :D
pinzdriver
sending unit
Post by pinzdriver »
First you did not have to pull the tank off to access the sending unit there is a small pnl in the upper right corner of the bed with 4 screws and you can get to it from there. :oops:
As for testing it you need a 24 volt test light turn on the key and with the test light and see if you get a pulse if so you may have a dead sending unit. You can also disasemble the unit and see if there is any broken wires in side too.
hope this helps
tony in az
tony in az 73 pinz 6X6
pinzdoctor is the name,pinz repair is the game!
Lightningpinz
Post by Lightningpinz »
A real quick way to check is gound the sending unit wire and check for an empty reading, then open the sendin unit wire and check for a full tank reading. if that is what you get, then sending unit is bad, otherwise look at guage
McCall Pinz
Post by McCall Pinz »
Check the gauge's ground behind the dash too
norcal pinz
no i went a little over board and started taking my pinz apart first the windshield came off then the gas tank and tool boxes i decided to do some rust repair and i just wanted to get to bare bones !i am going to have all kinds of questions when i put it all back together!
WolfgangK
Post by WolfgangK »
There's a good description here: http://www.sdp-pinzgauer.org/html/fuel_gauge.html
Cheers Wolfgang
