my pinz failed emissions!
does anyone know of a place in salt lake city where i can go to get this truck tuned up enough to pass emissions? it smokes a bit at idle. i thought that was supposed to be normal. no?
1973 710m
i would assume so here. how else could anyone register one here?Erik712m wrote:Has any pinz ever passed current emissions?
i passed safety with my crazy garage parts stash leggo brake switch!
i just learned from dennis williams the jets in these carbs are likely 140's (it's from san diego) and i need 125's here at 4000 ft.
1973 710m
man on the mule
jets
just a bit of recent experiance to pass on... i just had a set of pistons and rings installed in my 710 and the differance was so great! before the new top end i smoked and used oil as if i owned an oil well. with the new top end i can let the little beast sit and idle for as long as my paitence wil alow and no no smoke and no oil use. when the job was done we found some really big jets in the carbs . i have a set of trashed carbs with the smaller jets ,so seemed a quick enough swap. i went on a run the next week and under really steep pulls i tended to bog .seemed to be starving. i got out the old manual and did the homework that i should have to begin with and found that the reason that i was starving was that i had changed the jets inside the little cover on the side of the carb but i didnt change the air bleed jets in the throat of the carb. the change to smaller fuel jets without changing the air bleed jets left me with a way too lean mixture. so..... if you change the jets make sure you get the 8 changed not just the 4 . my truck runs absolutely great now.
man on the mule. keep it real.
yours must be a 712? mine's a 710 so i drove it on the dyno. but... hm... maybe i could go someplace else and tell them it's full time drive!
1973 710m
michaelh712
ka,
I take mine to the state emissions garage, where they have been more than agreeable. First time my 712 did not pass, then I tweeked the carbs abit and leaned them out where it would pass. Every year since, they just write me a certificate without testing as they figure it does not rack up the miles.
Michael in slc
Michael in slc
michael! thank you!
where is this "state garage"?
is there a certain person i need to see?
how do you tweak" your carbs"? per dennis williams, i'm already buying the 4 125 jets....
1973 710m
I once threw a towel over the locker levers and said it was full time 4wd...
no dyno test! It helps that the majority of emission stations are "uneducated" where a Pinz is concerned.
It was a 710.
Since then I have insured both of my Pinzes as Antique/Collectable,which exempts them from emission testing here in Arizona.
Mark
Mark
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
68 Haffy
Nope - Utah has tougher registration laws than even California. Instead of a rolling date to exempt a vehicle for emissions (like most states use), Utah has a set date. Pretty lame. Truck and Antique licence are not an option either. When I had to pass my trucks, I would just lean the carbs out using the mixture screws on the carbs and even mess with the timing some times. The truck ran like crap but passed. You defiantly need to find a shop that is willing to work with you.ka wrote:ah.... ! i wonder if i can do the antique thing in utah!
Good Luck!
Wimps Need Not Apply
now that i've replaced the 140 jets with 125 jets (via advice of dennis) this thing runs way better! monday i'm headed up the pass to micaels712m's to get his aid in tuning this thing up. driving it legally registered should feel better, i expect.
1973 710m
