Source for new production turn signal switches found.
milesdzyn
Post by milesdzyn »
Okay so I found a potential source for the very hard to find turn signal switches for our Pinzgauers. :D
The company is called ISP West and they are selling them on eBay
Link to eBay auction Cost $109.00 + $10.34 s&h
Or if you prefer you could contact them direct?
Phone 310-637-2100
Fax 310-637-1019
Email: pimppride@vwispwest.com
Web site: http://www.vwispwest.com/home.php
ISP West part# 211953513G
Part Descr. VW Type 2 Bus Bay Window Turn Signal Switch 1968-1971
It may be cheaper from there web site $89.95 + $?? s&h
http://www.vwispwest.com/product.php?is ... 211953513G
Veiw their Catalog online: http://www.vwispwest.com/Catalog.php
Download their catalog, click the address.
http://www.vwispwest.com/zip_catalog/isp_catalog2.zip
OR
If someone prefers to have a German made NOS there is one available on eBay right now. $200.00 + $12.00 s&h
I have not had this part #211953513J in my hands so I can't comment on it.
Note BOTH of these are for VW applications not for Pinz's, so the color of the wires may be different and the length of the wires may vary from your original Pinz parts.
From what I have seen the mechanical parts are the same and function in the same manner as the Pinz parts. The cowl mounting parts are also the same so there should be little problems mounting these.
If we're lucky they will be readily available in the future now that someone is reproducing them. If someone does buy one of the reproduction units please let us know what they think of the quality level.
I already have an original VW Type 2 switch as a spare otherwise I would get one myself.
Here is a link to some photos showing the VW switch compared to the Pinz switch
Miles
'73 Pinzgauer 712M
Miles,
Thanks for info on the new source. What is the difference between the 513G and the 513J ? I had been told that the 513J which is for the '72 Bus is the same as the Pinz switch but have not had anyone confirm it. I've never been able to find anyone with a 513J in stock and it is always listed at over $200.
WolfsburgWest http://www.wolfsburgwest.com/cart/Detai ... 211953513J also sells the switches but never seems to have them.
It looks to me like the 513G should work fine. I just ordered one from ISP West. I'll post what it looks like when I get it.
milesdzyn
Post by milesdzyn »
They seem to be the same visually but the Switch I've actually held in my hands is the part #211953513G, as seen in my original post a while ago.
viewtopic.php?t=2613&highlight=turn+signal+switch
I have not had the other part #211953513J in my hands so I can't comment on it.
Miles
'73 Pinzgauer 712M
I get these at a local VW shop in town for around $75, but you must check to make sure the housings mate properly or just install the entire assembly(requires steering wheel removal) 8) The main differences I find in the VW switch is the direction of the colored stripes on the wires, and small variations in the switch housing design.
eaweidner
Post by eaweidner »
I have lost one of the two screws for tightening the switch to the steering column. Does anyone have one or can someone direct me where I can find a replacement? It seems to work fine for now, but I constantly have to check the unit for tightness.
Thanks!
Eric Weidner
SE Iowa
1972 Pinzgauer 710 M
Hellfish Pinz
andy
Post by andy »
Miles, thanks to your pictures I was finally able to get my blinker assembly put back together properly so that it didn't wobble on the steering column. It sort of sagged for a couple of months before your pictures showed me that we had the half moon piece in wrong. Thank you again.
Andy
A bar F
The buck STARTS here
www.deerleaseservices.com
andy
Post by andy »
Eric, have you contacted the place Miles posted the link to? They would probably know. Just a thought.
Andy
A bar F
ka
Post by ka »
attaching screws are m4's. i had to buy some socket head caps at mcmaster, 12mm long, sand the head diameter down to fit into the conterbore. much better than original.
1973 710m
Great timing on this thread. My turn signal switch has been on the *blink* for a couple years and quit altogether last week. Then it started working again, but who knows for how long.
