How do you guys maintain your batteries during the winter? I have 6 motorized vehicles with 9 batteries(pinz, 4 wheelers, lawn mower, RV etc) that all have batteries and I am tired of replacing them in the spring.
Do you use trickle chargers or what?
batterie talk
batterie talk
Wimps Need Not Apply
I think if you hook up some solargizers to your batteries, they should be okay. eBay is a good source for them if your patient and look for a good deal.
Miles
Miles
'73 Pinzgauer 712M
'73 Pinzgauer 712M
Aaah,only 6 vehicles
I've been changing to Optima Red and Yellow tops as the lead acid batteries have gone bad. If there isn't a parasite draw, you can easily go 6 months between startups. Each of the vehicle also has an (externally mounted) innerconnect connector for for jumpstarting each other, plus for a maintainer charger and a high amp starter/charger ( with the same connectors).
I am also modifing a 3 pin connector ( for my 24v vehicles) to allow the 2 pin connectors to plug into to for jumping/charging either battery with 12v. The connectors are such that they cannot plugged in backward, plus I have alligator clip pigtails ( w/ polarity leds) to allow jumping to/from another person vehicle.
I'm a big fan of Plug n Go systems......I'm also too lazy to open the hood/hatch everytime
Harbor Freight
Sorry no pictures but got this one (x7) at Harbor Freight ~ I use 2 on the boat, 2 on the Pinz, 2 for the Jet Ski's, one for my buddy's boat stored all in Havasu. Have used them for over 4 years, have not replaced a battery yet, and sometimes the boat sits on the charge for 3 or more months. I run them all through a Strip plug device in one way or another.
Chicago Electric Power Tools
AUTOMATIC BATTERY FLOAT CHARGER
Skip the aggravation of a jump-start by keeping your vehicle's battery fully charged.
Use on 12 volt batteries while in storage or during cold weather
Floating circuit maintains a full charge without overcharging
Automatic safety shutoff
10 ft. long leads with copper clamps
ITEM 42292-7VGA
Everything always starts....
ITEM 42292-7VGA
Pinzing is AWESOME.
