My head unit is draining my batteries. I don't drive the pinz very often and when I don't cut the power all together my batteries die with in 2 weeks from the small amount of power that the head unit is pulling.
I have seen a few different ways to hook up a stereo head unit. One I have seen is that a small battery has been added just for the presets on the radio. How are you doing it to where your batteries are not being drained?
How have you set up the power for your Stero Head Unit
Wimps Need Not Apply
Lightningpinz
I used an Astron unit for my 12vdc. It has an ignition sense to turn on the inverter. For any of the other units (Semlex etc) with out that capability add a relay to an ignition sense to control the inverter. Then I came off that to a 12vdc emergency light battery (12vdc @ 6 amp hours). The preset power is hooked to the battery. The main power has a relay hooked to the ignition sense lead. Key off battery supplies the presets. key on and the inverter powers up and power is applied to the radio. In the unit I built for work there is a big 12vdc emergency light battery. I have also used multiple 6vdc batts. Just depended on what was readily available. Most of the emergency batts are agms. Hope that helps
Pinz Enthusiast
I use a Astrodyne converter, output to a marine fuse panel (6 place) I also have a 400 watt Alpine amp that is drawing off the 12v + post of the first battery, a battery equalizer is used to keep the batteries equal in voltage, I also had my alternator rebuilt and it makes 55amps so my recovery time is very short, btw I have optima yellow tops and have yet to fully discharge them even with my big compressor set up and all my electronic gadgets.
Eric
Anaheim Hills, Ca
1996 LR Disco I
2003 LR Discovery SE
hope to get a 1969 Ford M656
Anaheim Hills, Ca
1996 LR Disco I
