Brake Light Sensor
Brake Light Sensor
Greetings All
Can anyone tell me if there is a way to adjust the sensitivity of my brake light switch? I have adjusted my brakes and the pedal does not depress as far as before and unless braking pretty hard ddoes not activate the brake lights.
Sam
Sam
pinzdriver
stop lite switch
the stop lite switch has gotton hard on the inside you need to replace it.
tony in az 73 pinz 6X6
pinzdoctor is the name,pinz repair is the game!
There is no adjustment Sam, it's simply a hydraulic switch.
Just replace it and all should be OK.
An equivalent aircooled VW unit should fit!
BTW, I see there is a 710K in NSW for sale on Ebay ... Do you the guy?
http://www.ozpinz.com
Brake Switch
Thanks Guys
I will have a more detailed look tomorrow. Is it located in the master cylinder?
Peter I saw the 710K there too & no I dont know who it is looks pretty tidy though.
Sam
Sam
On the back of the master cylinder!Is it located in the master cylinder?
being a switch screwed into the BACK NEARLY INACCESSIBLE side of the cylinder, i created a bracket to mount a limit switch to a totally accessible area near the brake peddle arm. it's fully easily adjustable, high quality parts and cheap to keep. the spot they put that switch is rediculous - must have been a choice driven by parts they were forced to use.
1973 710m
My brake lights seem to flicker when the pedal is pressed and the brake lights stays on all the time. Fluid level is OK so I pulled the wires off the switch and the lights go out. Figured it was a bad switch???? I checked SWA and the parts manual and found a switch P/N 7101366062, can anyone confrim that this is the right part? Should I be checking for something else for the cause?
Scooter
Scooter
The brake switch (if original) is the weak link. I had one short thru the switch housing and catch fire! I never really got used to flames coming from under the dash in any vehichle. As said before,the VW brake switch (any V dub shop will have them,under 5 bucks) is the ticket.But it is a bit of a pain to replace.
Stock means no imagination!
Volvo TGB1317, .95% Morphed!
68 Haffy
68 Haffy
does anyone know what super special wrench could be used to get to that switch? i gave up and made my own limit switch that works off the pedal. works gr8 but i wouldn't mind knowing how to do it stock.
1973 710m
