I've got a (big) oil leak on my Pinzgauer engin.
Here's some pictures :
The base of the cylinder are oily. [green line]
There is a little of oil at the base of the push rod tube. [red line]
Someone have an idea ?
Thanks.
Cyril
you forgot the most important partYou will need 4 lifter housing gaskets, 4 intake port gaskets, 4 exhaust port gaskets, 5 oil return tube O-rings(one for dipstick tube), and 20 push rod tube seals, and 2 carb base gaskets if needed.
I'm pretty sure its metal to metal. When I was having problems with my pinz, Jim replied to a post and if I remember right, they get sealed with Permatex aircraft grade sealant. We use this sealant at work when reassembling the turbines at the power plants and it works awsome. Its alot more fluid than one would think and it seals up great.todds112 wrote:How are the cylinders sealed into the lower? Is there a gasket, some kind of sealant, or just friction fit?
