(Big) oil leak on my engin.
Posted: Tue Sep 23, 2008 4:16 pm
by Cyril
Hello from France,
I've got a (big) oil leak on my Pinzgauer engin.
Here's some pictures :
The base of the cylinder are oily. [green line]
There is a little of oil at the base of the push rod tube. [red line]
Someone have an idea ?
Thanks.
Cyril
Posted: Tue Sep 23, 2008 4:33 pm
Ok, now sit down and relax because this is a no brainer :shock:
It is time to reseal the top end at the very least :cry: The 30+ year old oil tube seals and O-rings are wet, the cylinder bases are very wet and should be removed, cleaned and resealed as well as inspected for wear while out.
So in short, it needs to come apart to be repaired properly :wink:
If the engine has a lot of blow by, you could re ring it, extending the life of the engine, the bottom ends are very strong and seldom require bearing replacement :)
Good luck on your repairs, just take your time and remember to get all your gaskets and seals before you start to prevent distraction an re-assembly.
You will need 4 lifter housing gaskets, 4 intake port gaskets, 4 exhaust port gaskets, 5 oil return tube O-rings(one for dipstick tube), and 20 push rod tube seals, and 2 carb base gaskets if needed.
You fogot!
Posted: Tue Sep 23, 2008 10:30 pm
by Kirby
you forgot the most important part :!: ....... BEER! 8)
now being from France, he may prefer Wine, but never the less, at the end of the take apart and rebuild you must have a reward! :D
Posted: Wed Sep 24, 2008 1:25 pm
by Cyril
Hello Jim and Kirby,
Thanks for the answer.
You confirm my prognostic.
A lot of work...
Cyril.
PS: Beer is OK. 8)
Posted: Wed Sep 24, 2008 2:45 pm
by todds112
How are the cylinders sealed into the lower? Is there a gasket, some kind of sealant, or just friction fit?
Posted: Thu Sep 25, 2008 11:58 am
by Oberon
todds112 wrote:How are the cylinders sealed into the lower? Is there a gasket, some kind of sealant, or just friction fit?
I'm pretty sure its metal to metal. When I was having problems with my pinz, Jim replied to a post and if I remember right, they get sealed with Permatex aircraft grade sealant. We use this sealant at work when reassembling the turbines at the power plants and it works awsome. Its alot more fluid than one would think and it seals up great.
