cracked distributer cap
norcal pinz
i must have tightened it to firmly to the adaptor plate on the civi. kit .IT cracked right where the bolt holds it down .Is there some kind of speck for this i will just go easy on the next one. has anyone else broken one this way?
710M 1972
710k 1974
710k 1974
Yep, the specification is:
"Just tighten it ONE tight, not TOO tight"
1997, 718 6X6 Pinzgauer
Pinz Enthusiast
yes installed a new rotor and forgot to shorten it's over all hight, I am sure Jim L. have a pic or 2 of the rotors for comparrison if your not sure, I usually just hold the rotor on a belt sander till it's at the right height.
Eric
Anaheim Hills, Ca
1996 LR Disco I
2003 LR Discovery SE
hope to get a 1969 Ford M656
Anaheim Hills, Ca
1996 LR Disco I
ExpeditionImports
Most of the time when we see this the adapter ring is installed first, then the cap is installed into the ring. THIS IS THE INCORRECT INSTALLATION PROCEDURE. Install the cap into the ring, then install the assembled unit onto the distributor. Might this have been the case here?
Just a little snug is all it takes......remember the caps are bakelight and will crack easily....
Scott Ingham
Scott Ingham
Vallejo, California
www.expedition-imports.com
Vallejo, California
