New To Pinzgauers...
Hellfighter17
Hello everyone. I am new to the pinzgauer world. We just purchased two 710 M's. They are both pretty much "plain jane", with no after market add-on's.
What advice do you have on things to do to these (including maintence). They both seem fairly worn (of course they are from the 70's) and don't wanna go over around 45-50 mph. I'm guessing this is about what they are built for, though. These will be used mainly on the ranch, but sometimes in town.
One thing I want to do is get some lights for the inside (like a dome light or something similar) and also off-road lights. Is it easier to find 24v lights, or do some type of 24-12 conversion? I can wire just about anything on 12v, but don't really know anything about 24v.
Any advice on these would be appreciated. Thanks everyone and be safe!
here's a gr8 24v t0 12v converter. it's also a battery eq (very nice to have).
http://www.solarconverters.com/equal1.htm
do you have pix you can upload or direct to (link)?
1973 710m
The data sheet does not mention if the converter is compatible with the voltage transients and spikes which do occurr on any vehicular electric system, or is rather suited for stationay applications with "clean" DC.ka wrote:here's a gr8 24v t0 12v converter. it's also a battery eq (very nice to have).
Did you actually install it on a vehicle?
Ugo
texas pinzgauer
Welcome to the forum and welcome to another Texan although Pampa is about as far from Houston as you can get. (What do you think, 9 or 10 hours???)
I will post a photo later and get the name of the manufacturer but I found a very cool "strip light" that has 3 individual LED lights and it works great. I've mounted it to the steel cross member and it's super bright.
You might take a run down to Amarillo and go to a lighting supply store and see what sort of battery powered items they have.
By the way, this light, I've added a velcro strip to it so that I can move to a location in the rear of the Pinz too.
1974 712M - sold
1973 710M - sold
1974 712M - sold
1973 710M - sold
converter/eq
ugo -
check this web page: http://www.pinztrek.com/pinz/mods/pinz_mods.htm
1973 710m
norcal pinz
hi and welcome, one of the first things i would do is change all of the fluids as needed engine oil, and the 8 gear boxes underneath. also flush the hydraulic fluid in the 4wd , and locker levers. then flush the brake lines out. and finally bust out your grease gun and hit the fittings. then at least you know that all of your fluids are fresh and that everything is lubricated properly. one less thing to worry about.
710M 1972
710k 1974
710k 1974
norcal pinz
Re: converter/eq
Thanks Ka, good advice!ka wrote:ugo -
Ugo
ugo - so do you think there's a potential problem regarding spikes/transients? i know they exist seeing how they eventually destroyed 2 sets of led taillights in a 712amb i owned. not sure if it's a concern with this eq, tho. any thoughts? i need to get another one for this pinz i have now.
1973 710m
Welcome to Pinzland! The 710s should do better than 45 mph. My 710M even with a ton of feed in it will do 55 easily. Takes a little longer to get there but once it's rolling it's fine.
I've gotten clip on LED lights at Home Depot for both my Pinzes and they work fine. I have one clipped to the sun visor on the driver's side and one on one of the rifle holders on the passenger side.
Get a good 24 to 12 converter. I use mine for my GPS. I use the GPS mainly on the ranches for feeder locations, but it makes a super backup to the spedometer.
Think about getting the Petronix ignition.
What kind of tires do your Pinzes have?
Follow the above advice about fluid changes, that is solid gold.
Good luck with your Pinzes and keep us up to date on your progress.
Andy
Andy
