Here is a "relatively" inexpensive 4 channel device that I installed recently.
Both the meter and the sensors came from Chief Avionics.
http://www.chiefaircraft.com/airsec/Avi ... ngles.html
and
http://www.chiefaircraft.com/airsec/Avi ... nders.html
$200 for the meter and $30 each for the thermocouples.
The meter runs on 24 volts out of the box. The thermocouples are intended to go under the spark plugs,
but I found that it was impossible to do that, so I put the thermocouples under the head bolt above the spark plugs.
The thermocouples only have a three foot wire attached. I had some type K thermocouple wire and connectors
that I used, but maybe you can order the thermocouples with longer leads.
